I am collecting some data in a buffer on the DSP which consists of X,Y,Z points combined with an analog measurement, and then transmitting the data points to the PC using printf statements. The printf statement looks something like:
printf(“MyData %3.3f %3.3f %3.3f %3.3f\n”,data1, data2, data3, data4);
Then on the PC I watch the console output for the MyData tag and parse the output lines.
However, it seems like these MyData lines are getting mangled under certain conditions. The characters are not coming through in the correct order, or else some other console data is being intermingled with these lines.
Does the printf statement get split across time-slices, so that the data gets loaded into the console buffer in different slices? Do I need to do a WaitNextTimeSlice() before printf, or use shorter strings If I want them to get transmitted
in one piece?
Toby
